Just read this thread as I have ordered some 5k HIDs and wanna be as legal as possible. Reading through this:
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
1. I assume is the regulation which allows OEM fitted HID converstions, which any car on here pre 2008 or so wont have... Am I right?
2. Is it possible to install self levelers? Or are they mega complex and not worth it?
3. People have mentioned headlight washers but that section makes no mention and only says 'like any other headlight'. Wouldnt that imply washers arent necessarily mandatory?
