I would agree that HIDs are usually done badly and almost always done illegally but they don't constitute the vast majority of modding.And judging from the cases I've seen around here HIDs are fitted by blind people after 12 pints.
@jnoiles - Have you ever driven a car with HID's? i can say after having them for 4 years there is NO WAY ill ever go back to halogen...it just doesn't compare when the only source of light is your headlights...halogens are for the most part tolerable, but HID's are better and make for safer driving...
INCORRECTLY FITTED HID's will dazzle...correctly fitted and adjusted ones wont...its all about the beam cut off, it has to be below the eye level of oncoming driver, if it is then no dazzle, pretty simple physics...
not true...only if the road surface makes the nose of the car deviate so much that the beam cut-off goes above the oncoming drivers eye line....such is the intensity of HID's, i aim mine LOWER than stock, and can still see fine because the penetration is so good...avoiding any glare...
thats the same drawback as with any lights...so no point worrying about it, you cant "ignore" a new technology because its too good at what it does...
and no, ive adjusted the healdight units to aim low, i use the level adjuster inside the car to correctly adjust the lights dependant on the load in the back, as it was intended...
take a look, ive put countless hours into perfecting mine, because i HATE the poorly adjusted fleabay kits, but refused to accept it cant be done right...
Yes I have. And they weren't all that. And I wear glasses. As for making driving safer, no they don't. They routinely dazzle other road users. Which makes the roads a more dangerous place.
in ALL CASES self levelling, Headlight washers and E-marked housings are mandatory to have HID's..you're just deliberately clouding the matter, its very clear cut and simple.
that's the oem ones and ones fitted to old fashion headlamps
I dunno, the transit we rented for Stanford was pretty useless on the country roads, I had to keep using full beam. I assume HIDs would have greatly improved things?Right. So that would be almost all HIDs on the market then. And I stand by my comments, if you need HIDs to be able to see you have no business behind the wheel. Not you specifically, you as in anyone.
Ah, the number thing... no, I didn't think to do that. Would that have made a difference?did you set them to full load?
