Installing Microphone
Microphone Installation
The microphone is located in the header console, which would have been removed to drop the roof lining. If you haven’t got a Sky Roof or alarm, then simply connect the 2-pin connector coming from the roof console into the microphone, and then push it up onto the light fitting.
If you have the Sky Roof, an alarm or both, you’ll need to take the microphone out of the new unit (undo the three small screws on the grey plastic framing, and remove the microphone from it) and install into your old unit. Then, plug back in and push the unit complete with microphone onto the ceiling light.
