My Panda is idling a little bit rough and is very intermittently misfiring on one of the cylinders. I don't believe the plugs have ever been changed from OEM. I did an OBD scan but no codes. So changing them for some NGK iridium plugs is probably a good idea (looking at NGK DCPR7EIX).
How tricky of a job is it? From what I've seen it's a little fiddly since the plugs aren't very accessible. Usually I'd hand tighten first before torquing to avoid cross threading but I'm not sure if you can with the positioning. Any extra tools you recommend? Obviously a 16mm deep socket and a and a wrench but 3/8 or 1/2 wrench?
Struggling to find any 16mm deep sockets that are not 1/2 which I'm worried about being too much torque (although buying a torque wrench and setting it to 25nm should prevent that). Probably overthinking it.
