![]() | #136 | ||
Posts: 5,562 Thanks: 279 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) I used tank sealant after I had cleaned it using small gravel and a weak phosphoric solution. Time will tell as I hate those inline filters. There is a gauze on the pickup tube and I think there's one at the carb...I must check that
![]() | #137 | ||
Posts: 5,562 Thanks: 279 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) Connie is exempt for road tax and MOT - I've applied and received the exemptions. However, as she has been off the road for 14 years, been stripped and had loads of new parts fitted it made sense to have her tested for piece of mind. It's also proof of roadworthiness (which you still need to prove), at least on the day. One tip I picked up from the MOT station. If you don't have an MOT and need to make an insurance claim a number of insurance companies are insisting on an engineers report before they pay out - the cost of the MOT looks good value in comparison. Another suggestion (not sure if true) is, when they do random spot checks for MOT's you are more likely to get pulled over if you are exempt (and without MOT) to ensure that your vehicle is roadworthy.
![]() | #138 | ||
Posts: 5,562 Thanks: 279 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) That's what I would have thought but there is nothing in the water pump housing to bolt to. All I can think of is that there must have been a separate bracket at some point but this has been lost. The cable tie will have to do for now, I'll fabricate a new bracket in the future.
![]() | #139 | ||
Posts: 253 Thanks: 8 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) The mounting point is missing on my water pump. Looking at the casting it looks like it should have been there at some point. I suspect that it would have been a bad casting that got through the Fiat quality control back then ![]()
![]() | #140 | ||
Posts: 253 Thanks: 8 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) On further investigation, the mounting point has been ground off to make room for the alternator.
![]() | #141 | ||
Posts: 253 Thanks: 8 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) If you have followed the other thread on overheating you will know that Connie made the journey to her new home successfully (of sorts). I'm now faced with the problem of how best to store her over winter, as the garage is going to be full of boxes for several weeks (if not months) and I don't want to undo the work on her so far. I have a cover to put over her once we get a few dry days (from a VW... they must be huge by comparison based on the excess material) which will help. However, my biggest concern is with the drum brakes. These used to seize on before the rebuild (if left standing for a couple of weeks) and I don't really want to go to the time and expense of rebuilding them again next spring. The problem is the driveway to our new home is on quite a slope. If I keep the handbrake on I expect the rear shoes will most likely get stuck on. On the other hand if I use chocks under the wheels I suspect that this won't do the new tyres much good if left for a long time. Has anyone had to store one of their vans on a slope before? And if yes, any tips?
![]() | #142 | ||
Posts: 358 Thanks: 20 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) Hi Gary. thankfully we are flat here, just managed to get our 900t inside for the winter this year. You could put the van on some very old tyres that are destined for scrap ie not road worthy and chock it against them. Tim
![]() | #143 | ||
Posts: 253 Thanks: 8 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) Hi Tim Shame I didn't think about that before I had the old tyres taken off the 12" rims. While I think about it, anyone interested in a set of 5 12" rims? 3 are okay to use as they are (need sprucing up with a clean and polish/paint) but the other two need repair to the valve seats (I used to have inner tubes in them - MOT's weren't so strict 15 years ago). With a bit of luck I'll be able to clear the garage and get Connie undercover before the winter sets in proper.
![]() | #144 | ||
Posts: 358 Thanks: 20 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) Hi Gary. best inside if at all possible. At least you could put some of your stored things from inside your garage inside Connie if it helps clear the garage space. with careful protection of course. Tim
![]() | #145 |
Posts: 1,926 Thanks: 102 Trader Rating: 1 ![]() | Re: 900t Restoration (Connie) The problem is the driveway to our new home is on quite a slope. If I keep the handbrake on I expect the rear shoes will most likely get stuck on. On the other hand if I use chocks under the wheels I suspect that this won't do the new tyres much good if left for a long time. Has anyone had to store one of their vans on a slope before? And if yes, any tips?
__________________ Noop now known as Nooplebe (i.e. in the way wherever he goes) 🐼 Last edited by The Panda Nut; 24-11-2020 at 20:20. |
![]() | #146 | ||
Posts: 358 Thanks: 20 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) Hi Gary. If you dont manage to get it inside you could put in a solid ground mounted ring and lock the camper to it with a chain and then have no need to have the handbrake on, this would act as a security lock as well as stopping the van rolling away. Tim
![]() | #147 | ||
Posts: 253 Thanks: 8 Trader Rating: 0 ![]() | Re: 900t Restoration (Connie) I just have to remember to take Connie out for a run every now and then to make sure nothing else seizes up and to avoid flat-spotting the tyres (if left unmoved for a long time).
![]() | jumonk73 | 850T / 900 | 3 | 20-04-2015 21:03 |
![]() | phate316 | 850T / 900 | 6 | 23-07-2013 10:26 |
![]() | Kmorganx | 850T / 900 | 22 | 23-07-2013 10:19 |
![]() | Badget | 850T / 900 | 0 | 24-08-2009 19:56 |
![]() | LeeP | 850T / 900 | 1 | 26-07-2007 17:06 |
