Technical  Koalar random thoughts
Thought I post on here as the information on sealing rings is hard to come by
Oil filters
1.2
There's two types notice the engine number of the swap over
The early ones are longer,
A it the diameter
H is the length
C is the outer diameter of the sealing ring
Also notice the bypass pressure is also different (2.9 PSI)*
Counter intuitive the shorter filter has more volume
V ≈ 307.91 long
V ≈ 335.7 short
That because the radius is X3.14 so it has a larger effect than you think
That's not to say it holds more oil it depends how the space inside is filled
Also notice the bypass pressure has altered
I don't know why the filter was changed, proximity to the exhaust, just a stupid guess, But I don't see it as a down grade
There are other filters from the fiat range that also fit
Again, just a guess - but Fiat have also changed oil specs over the production run. Perhaps changing the viscosity of the recommended oil might be the reason for the change in bypass pressure?
Fortunately the 1.2 unit, at least in non-VVT form, isn't an oil sensitive design, nor is it highly stressed; so long as it's got a quantity of something resembling engine oil between the min and max lines on the dipstick and a filter that doesn't leak, it's likely to outlast the rest of the car.
Grease the choice is massive and as formulations change the applications become blurry
Lithium
White
Aluminium
Copper
Red
Brake
And many more
copper grease
Original was used in high temperature applications, steam pipes, exhaust bolts and so on, it was not a lubricant as such
The theory is there is suspended copper in medium,.as the heat burns off the volatiles it just leaves a slippery copper coating on the fastener, this prevents galling from a dry steel to steel contact
Brakes are a.dodgy area, it's effectively band by some manufacturers as it voids warranty on ABS if found, yet other manufacturers recommend using it.
Red grease
Was originally red so it was easily identifiable on the shop floor, it's resistant to hyro-carbon solvents such as petrol, diesel, hydraulic fluid and is safe on rubber (yes I know it's not real rubber)
So is ideal for say the internal seals on a brake caliper rebuild
Silicone grease
Is also "rubber" safe but is more resistant to water, it's also widely used on none metallic moving parts
Lithium grease
The most widely used general purpose grease, it's both water resistant and high temperature, but should not be used on some "rubbers" or plastics
Lithium
White
Aluminium
Copper
Red
Brake
And many more
copper grease
Red grease
Silicone grease
Lithium grease
Just to add to this, I bought a tub of this stuff: https://silverhook.co.uk/Grease-Ceramic-Anti-Seize-500g Read the description, it's interesting stuff with a lot of applications. I especially like using it on exhaust fittings - the greasy stuff burns off leaving the ceramic behind which prevents stuff corroding together. I was going to use it on brakes but I find it a bit sloppy and runny so use this stuff: https://www.granvilleoil.com/prodInfo?pID=775 which has much more the consistency of the old copper grease.
Corrosion
Electroplating double-sided
immersion in zinc electrolyte under current
zinc layer 8 - 16 microns
From 2007
zinc layer 10 - 12 microns
Unpainted areas will loose approximately 1 micron per year
From 2007
Interesting.
That would suggest a useful structural life of about 15 years for the bodyshell (10-12 years for the sacrificial zinc to be consumed, then 3 years or so for serious corrosion to set in).
Coincides with the age when we first see cars needing sill patching at MOT time.
One of the gauges not at zero when the ignition is off
It's a fairly common issue
Battery runs flat and the pointers bounce hard on the stops, with a clicking noise
They are only a push fit so spin slightly on there shaft
They can be spun back to zero, only spin the pointers the same direction as in the video below
Don't forget to fix the original cause first otherwise you'll end up back to square one
Full tear down below
Just adding here so I can find them again
Fuel level in the tank
Resistance value
Full tank 33±3 Ohm
3/4 76±3 Ohm
1/2 134±3 Ohm
1/4 206±3 Ohm
Reserve 235±3 Ohm
Empty 299±3 Ohm
Pin 5 and 6
Ride heights
Rear
Full tank, tools and spare
1.1
1.1 VAN
1.2 8v
1.3 JTD 16v
1.3 JTD 16v VAN
4WD Climbing
4WD Trekking
1.4 16v
641.5 mm
642.7 mm
642 mm
639.5 mm
645.2 mm
678.1 mm
683.8 mm
621 mm
Got the car here for a few day
1.2 petrol 2011
Going to post a few pictures and video of some simple and basic tests
My well be a bit random as they pop into my head and might sort them into the proper order later
Morning koaler I'm still trying to fix the petrol gauge problem I'm almost convinced the petrol float is ok I used the multimeter set at 2k ohms at empty it reads.290 at full it reads .033 I don't know if this is correct or not what are your views please
That correlates with the results in post 69, so your sender is 100% ok
Any idea what my next step is I have heard there is a fuse somewhere but I thought if it's blown I wouldn't get any reading at all and the gauge does go upto over a quarter Iv e also read the earth strap underneath the battery tray might need cleaning up any information welcome
How much fuel are you putting in
He's putting in about roughly £20each time but last night we let it run dry so we could start a fresh. Something I forgot to mention when we first bought it we parked it outside on a slight decline and as I went to turn it off I noticed the gauge started rising to the correct level to the amount that was in the tank I switched it off and it was back to its old position
Cheers I have taken the battery off but can't find the earth strap to see if it needs cleaning
Any heavy duty cables in the engine compartment are worth checking and their connection points (remove, clean-up and remake to be certain)
It's unclear what the symptoms are , maybe post a new message in the thread that you undoubtedly started on the subject to bring it up the list rather than filling this thread up?:)
Under the battery tray
Under the clutch slave
On top of the gearbox here
Seeing as the starter motor working, 200+ amps
I am sure it would cope with the 0.01 amps of the gauge, which in any case does go through this ground
Anyhow you hove a multi meter
Just do a voltage drop test under(cranking) load from the battery to engine block
Around or below 200mv and your good to go
You have no symptoms of a bad ground, and the gauge is working as expected, no sure what we are fixing
