Technical Thoughts on axle change (drum brakes)
koalar
Distinguished member
Cheshire
Use as a note pad on axle swap
Once all the info is down it can get written up
Part numbers for the hydraulic hoses and pipes, ABS and drum
Be aware there's three types of drum brakes
Bosch none ABS very rare
Bosch ABS the most common
Lockheed/Delphi eper shows from 2009
Bosch and Lockheed use completely different wheel cylinders and backplate
As far as I can tell the drums are the same I fitted Bosch to a Delphi set up as they were at the time half the price
