If its otherwise tidy, as a 2011 car with presumably £35/year tax, there's probably still some value in it for someone who can do the work themselves
Yea, was a naive decision and one I won't be making again. I got a good use of it though and know what to do better in the future. Already received offers for a couple hundred quid on facebookThat MOT history reads almost the same as one I told my nephew not to buy.
It looked nice enough, but had spent its entire life alternating between really short journeys and being parked on a grass driveway.
It looked very crusty underneath, to the extent that even the trims on the steel wheels didn't sit properly due to the surface rust.
Can't argue with thatYea, was a naive decision and one I won't be making again. I got a good use of it though and know what to do better in the future. Already received offers for a couple hundred quid on facebook
Thank you. Once that chunk came off I was thinking the same and am not driving it anymore. Already had offers for 300+ quid on facebook marketplace with the issues disclosed. Hopefully I'll be getting a decent bit more than scrap valueI'm coming to this thread rather late, but I'd agree with those that are saying this is dangerously corroded and unroadworthy; you're certainly
not going to get another MOT without replacing the beam.
Unless you're going to be doing all the work yourself, repairing this car will cost way more than it's realistically worth, and even then, it's marginal.
Personally I'd stop using it now. That beam could fail at any time, and if it caused an accident, your problems could multiply fast.
Take the money and let it go, its an accident waiting to happen. Onwards and upwards.Thank you. Once that chunk came off I was thinking the same and am not driving it anymore. Already had offers for 300+ quid on facebook marketplace with the issues disclosed. Hopefully I'll be getting a decent bit more than scrap value
Which shows how desperately difficult it is to find a decent, cheap ULEZ compliant £35 RFL used car.Already had offers for 300+ quid on facebook marketplace with the issues disclosed
Panda sills are wierd.I can only guess what the state the rest of the bodyshell will be inside, but I'd expect a borescope examination of the interior of the sills to show significant internal corrosion.
SD60 TNE
We had a 2011 sold a year ago for £600. It was running well and exceptional bodily it also had a full MOT. Ai £200 I would accept and move on as soon as possible. Its an OK offer and a lot more than scrap.Yea, was a naive decision and one I won't be making again. I got a good use of it though and know what to do better in the future. Already received offers for a couple hundred quid on facebook
You can never tell just by looking
Wire brush and inspect for thin metal and cracks
Shocks look very old, check for oil misting and the top rubber bush
They can look bad but only be superficial and visa versa
If there's a reasonable amount of metal and no cracks, a small amount of maintenance now and it will probably our last the car
Check the brake pipes for corrosion also
Bottom shock bolt does not look too good they are normally pretty good
Check this seem for paint bubbling, surface rust is fine where the jack has scratched the paint off
Yes actually last two years advisories listedIf you have axle stands, I'd be tempted to undo the two top shock bolts and drop the springs out,
A quick wire brush and paint now will stop them going on the MOT as an advisory
Talking of MOTs. have you done a history check
It usually gives a indication of how the car has been looked after
Same advisory a few times is normally a sign of lack of maintenance, or it's not genuine
If something drops of advisory, that genuinely should be there. Point to a weak MOT being done
It's not 100%, because I have replace something and it was still an advisory on the next MOT as it was just copied and pasted from the previous MOT
That.If there's a reasonable amount of metal and no cracks, a small amount of maintenance now and it will probably our last the car
