Technical Koalar random thoughts
Let's start with Turing the ignition on
You should here a buzz from under the rear seat
Depending on your hearing it can be very faint
A reliable way is to put your ear to the petrol fill while a friend turns the key
Please note everytime you turn the key on and of the ECU sends a signal to start the motor regardless of what the line pressure is or what you read elswhere
This is me turning the ignition on and off several times
Still no noise
There still two checks before we need to take the rear seats out
On my car euro 5 it's fuse F21 15A and relay T10 20A the owners manual will identify yours
sods law you have broken down in the middle of nowhere, it's worth swap them for identical one in the fuse box before calling for rescue you can live without some things like aircon, heater but not without fuel to the engine
My 100HP did this after the lockdown layoff. It turned out to be a relay. The Body compute had no power. All relay and all fuses got (one-by-one) pulled and tested. All were ok but it started after that was done. Suggest start by swapping BCM relay with headlights relay (all are same spec) and see what happens.
Right you still no noise
Fuses and relay are fine
It's not the inertial switch
There one more quick thing you can try
Really needs two of you one to turn the key while one taps under the tank
Sometimes the pump sticks as they get old or have been left standing
You can just reach it without jacking the car
Lifit the seat out
There's two cables we are interested with
These can be backed probed with a T pin and a good ground, I used the seat belt bolt as a ground
Yellow and purple, the supply, should be battery voltage as the ignition is switched on for few seconds
Red and purple, the ground, should be less than 1 ohm
This are the colours in my car, they all appear to be the same but I haven't checked every combination
LHD
RHD
4x4
All models
All years
One bit I missed, said it would be all over the place as things pop into my head, This should have been first.
It does not affect many people and very rare and also depends on body computer version fitted
If you have a high end model and it's fitted with an alarm, extra security,
Locking with the remote, then the battery goes flat and you open the door with the key, can lock out some features such as the diagnostic port, you need to charge the battery and lock and open with the remote before carrying out any diagnostics
One last thing on fuel unless someone chimes in with a suggestion
The easy way to drain the tank or check fuel is reaching the injectors is to disconnect the fuel rail quick connector near the throttle body and capture the fuel as you switch the ignition on
Please do it safer than me, I have only done it like this so it's Visable in a video
Moving on to the dash
A lot of information can be learnt from just carefully watching the display
But first here a myth
You need to wait for all the cycles to finish before starting the car
Does it happen, yes, often you can limp by for years without addressing the problem, I know as I have done same
This is the first start after the car been left for a few day, This is a flyby wire model notice how quickly it drops from 1200 to 750 rpm, from memory cars with an idle control valve were a little slower
Also notice how quick from the clock coming on to the sound of the cranking less than a second
Here's the same car with a fairly flat
Battery
Listen carefully you can hear a slightly slower crank speed
Watch the behaviour of the rev counter, yes I know the lights are on just me trying different thing and forgot to retake the video, compair it to the video above, see the delay before they jump up
The body computer (BSI) needs 6-18V
If the voltage falls below 6V it looses its ability to keep it's RTC (real time clock) running and you will get this,
A high percentage will be the battery, but not always
It's important to set the time as this is often the first warning along with possibly a longer crank time that the battery is getting old
You don't need expensive diagnostic and test equipment, most of the time
This is a £5 Bluetooth obdii reader and a android smartphone and free software, giving better results than an expensive volt meter/multi meter, For around £15 you can do the same with a stand alone hand held unit if you don't have a smart phone or laptop
Be careful if you use an iPhone, it does not use standard Bluetooth and need a special obd2 dongle
Look at this graph, this is a marginal battery. Probably will not last the winter. Less than a second and the voltage while cranking has dropped to below 9V (the car will not start below 6V and it's still warm outside) most multi meters would still be still showing 12V
Not perfect as there is roughly 0.2V error but vastly better than being 3V out
This test is directly equivalent to a battery load test but for the fraction of the cost as you are using the starter as the shunt (load)
Here the warning lights start sequence
It actually tells you quite a lot
This tells us
Antenna isn't broken
Key transponder isn't broken
BSI (Body computer) is up and comunicating
ECU (Engine computer) is up and comunicating
Dash to BSI is communicating
This tells we have fuel, always a good start
These two lights (charging and oil) should be lit with the ignition on, and should only go out when the engine is turning over
Here they are not lit at all as I have I disconnected the earth, If there is high resitance, they go out as you turn the key to crank but the engine fails to turn over
These two lights are the wrong way round
The engine check light should be on and the immobiluser should be off
Engine computer has lost its ability to talk to the body computer
The engine block should be ground there should be very little voltage between the engine and the battery negative terminal even when cranking, the battery negative and block are either end of a thick cable connecting the two
Here you can see the bock go slightly positive (test light dim) when the ignition is switched on and battery voltage (test light bright) as you try and crank
If I put a smaller battery in I twist the strap to shorten it, no need to mess with bits of wood
Inlet manifold pressure should follow revs
Here near sea-level
Starts engine Off @ 100 kPa and under 40 kPa at idle
Green RPM
Red inlet pressure
First start
Idle plus blip
Contant blips
Kind of counterintuitive but if the car is running on 3 cylinders it does not effect the inlet manifold pressure (unless there is a backfire), the piston is still going up and down, the valves are still opening and closing, it's still working as a pump
Here the car with cylinder one injector disconnected
Compare to above the revs are different but not the inlet pressure
Check for inlet manifold leaks
Block the tube going to just under the throttle body, put your hand over the throttle body
The engine should stop immediately
Vacuum should be held for a few seconds, if not you probably have a leak between the head and inlet manfold
If the engine isn't pulling much vacuum and passes the above test, you either have a serious mechanical error or the sensor isn't reporting it correctly
Odds would be a timing issue
Evap
Remove the blue pipe, no suction should be felt, with the small pipe that goes under the throttle body blocked
Remove the electrical connection, block the small pipe again, wet you finger, a slight vacuum should be felt, it's easily missed
There is no difference seen by the map sensor
Pipe removed
Pipe and electrical connector removed
Manifold pressure red line, finger on and off the evap solinoid, is flat lined
Crank sensor
If you have a rev counter
Normally they either fail from cold start
Or when hot
Just carefully looking at the rev counter (if your car has one) during a cranking no start would help to diagnose this
Worth observing as a crankshaft sensor will not set a code in most cases
