General  Random questions
chesterfield
Hi all, couple of random questions for you.
1) do the headlight units have a vent hole anywhere on them?
Some idiot...(me) didnt put the bulb cover back on correctly and now one is full of damp, been using the headlights all the time to try and dry it out, wanted to make sure it wasnt blocked, stopping the warm damp air escaping.
2) on the door cards can the coloured insert (pictured) be removed seperately?
Have a chance to get a much less worn set of seats, blue instead of yellow, wanted the inserts to match.
I know that i could change the whole door pannel....however mine are the light gray, the others are the dark gray.
Thanks guys
The cloth trim part of the door card is attached with heat mounted plastic rivets. You could probably remove it but risk scrapping the whole thing. That said, used door trims are cheap enough to experiment with.
Always make sure the plastic sheet that ruled to the door is not damaged. That's all you have to stop the trim going mouldy at the back.
