Hi all - in the last few months the clutch pedal in my 94k 2009 100HP has become very heavy. The gears engage properly, there’s no untoward noises and the biting point seems fine. I’ve read anecdotally a heavy clutch pedal is a sign the clutch needs replacing on a 100HP, is that the case or should I look at changing the cylinders first? The clutch and master cylinder have not been changed from new.
Thanks in advance.
There's always exceptions
But generally yes,.new clutch is normally needed
I have never known it be anything else yet, if it's very stiff
It worth putting some silicone grease down the clutch slave, remove the rubber cap and put it inside, these bind quite badly, but you normally other symptoms, clutch pedal sticking down and or squeaking,.it depends how stiff you mean.can make a notable difference, if it not terribly stiff
You should be able to put an endoscope down the inspection hole and investigate the fingers on the end of the pressure plate
Running the car with a stiff clutch does lead to other problems,.it not unknown for the pedal to snap, they a designed to break in an accident
Or the release bearing to be pushed too far into the pressure plate causing more damage
Not sure if anyone else has a easier way to diagnose,
@irc @portland_bill
94k is that on its first clutch ?
