- Joined
- Sep 14, 2009
- Messages
- 20,105
- Points
- 4,011
A new slave cylinder (e.g. LuK) will cost about £35. Get one and remove the original. If it's substandard fit the new one. If its OK return the new one. Cost is postage. No need to faff with the plastic hydraulic pipe. Just pull the hairpin clip** and pull the hose end out of the cylinder. Wrap a small cable tie around the clip to keep hold of it when you pull it out. They are inclined to ping away into the weeds.
If the wrong clutch has been fitted you'll be replacing everything anyway. My diesel had a standard 1.4 petrol clutch. The centre was dropping to pieces.
I use bettens into the wing drain channels with a 3 x 2 timber over the top of the engine and a ratchet tie down strap. Wrap strap under the gearbox up against the bell-housing and over the 3 x 2. Put a stand and wood blocks under engine to support the weight and remove gearbox bolts, mounting, driveshafts, etc. When you pull the gearbox off the engine the strap will take its weight. Loosen the strap, use a jack to lower gearbox down. I like to do it in stages alternately loosening the strap and lowering the jack but with help you can do it in one go.
The strap is great for putting the gearbox back into the car. The hard part is aligning it for angle and especially rotation. The strap takes the weight while you set it up to slide into place.
An old Panda gearbox will have a hardened input shaft oil seal and possibly a worn bearing. There's a guide on this forum for replacing the parts. Failure to fix these will quickly lead to oil on the clutch.
