Over the past few months I've been slowly making a table out of a damaged mk2b Punto alloy wheel. Just thought i'd show you all the final result
Ill let the pictures do the talking
I started off with a bent Active Sport 15 inch alloy sat on top of half a bar stool
Mock up of the disc and caliper arrangement
Brake caliper stripped, shot blasted then powder coated red
Stand powder coated gunmetal grey
The wheel was also refurbished both inside and out
A new rear disc from a 1.9 Grande Punto was then mounted on top of the base
Caliper built back up, pads fitted and bolted to the disc
Wheel mounted
6mm thick toughened glass ordered. Custom cut with 4 holes with a PCD of 4x98
Even Fiat like it!
Wrightyy
Wheel mounted
Even Fiat like it!
Wrightyy
