Rogereld
I have a left side rear coil spring with a bump stop "resting" inside it. The right hand rear bump stop has completely disappeared. Is this a common Panda 100hp problem?
Original Birth working well on mine.As per @irc
Febi quality does not look good
Original Birth looks better but I haven't tried
Rear Shocks Upgrade | FIAT Panda (Mk3)
Never lift the rear of the car by jacking in the middle of the twist beam; it's not designed for this kind of point loading and you risk permanently distorting it. This will throw out the (non-adjustable) rear suspension geometry and excessive tyre wear will result. When these cars were new...www.fiatforum.com
I don't have a difinative answerThank you for the very helpful link to the recent "rear shocks upgrade" thread. My apologies for being new to this forum and not fully up to speed on finding the information myself. I will have to take a good look at jacking points. I would normally use a trolley jack at or near the specified jacking point to lift the car so I can place an axle stand under the car. As I want to leave the suspension spring free to work on I will have to take a good look at the best point for axle stands. I may want to get a bit of paint on the spring trays at the same time as they are looking a bit rusty on the surface.
I am looking online to order a couple of bump stops. I have read previous comments advising I ensure I get the correct ones for a 2010 Panda 100HP, and some other comments suggesting alternative suspension modifications. For now I want to keep to the original suspension setup.
I have read comments suggesting recent Febi stops are very difficult to fit. I have found Original Birth stops listed for the Panda 100HP but only specified for MkII dates up to 2009. S4P do not include the later MkIII Panda in their drop down list. The Febi and Original Birth bump stops both look different to the one I have hanging loose inside a rear spring. I am preparing to order the Original Birth Bump Stops from Shop4parts but as they do not look the same as the one on the car, and following previous cautions about ensuring I get the correct ones I am seeking some advice.
Are these the correct ones?
S4P8572 Rear Bump Stop
Phone number took a bit of finding. Not listed on the S4P website but some googling and a quick look at photos on street map helped me find a phone number for GGB motor factors (Incorporating Shop4parts).I don't have a difinative answer
I don't have an electronic part catalogue that includes the 100HP
The suspension was slightly tweeked around 2007 I don"t know exactly what was changed apart for the spring rates
As far as I know the rubber buffer as fiat call it is the same on all none 4x4 and is a critical part of the suspention, unlike most suspension the rubber buffers act as a spring assister when the car is fully loaded.
I would phone shop4parts they are very knowledgeable
50706353 looks correct alternativeI still can't find the paperwork for my replacement bump stops, but my son's 56 plate 100hp had ORIGINAL IMPERIUM 25866 bump stops fitted about three years ago.
They are still going, so outlasted my Genuine FIAT ones that had been on a shelf for at least 5 years before they got fitted.
However the cross-reference part number shows as 50706353.
Where are you finding 50706353 for 16 euros? Best I can see is for 35 euros in Greece.
www.autoricambisicilia.it
I think I got this advice from @jrkitching: I use a trolley jack with a block of wood under this reinforced section of the body, then place axle stands at the indicated jacking points on the sills, with wooden battens to spread the load and clear the seam.I will have to take a good look at jacking points. I would normally use a trolley jack at or near the specified jacking point to lift the car so I can place an axle stand under the car. As I want to leave the suspension spring free to work on I will have to take a good look at the best point for axle stands.
