There are different grades of polybushes for different applications. Trackday cars and full-out race cars use bushes with almost no movement. On a road car they are seriously uncomfortable and also tend to transmit more force to other components.
Even "road grade" polybushes feel stiffer than original "rubber" bushes. I tried some in my 100hp when bottom arms were on back-order and they were OK, but definitely less compliant than standard. I swapped them out for new bottom arms when they were back in stock. I now change out the rear bushes if the ball joints are OK - standard 100hp spec bushes are available separately quite cheaply and I have a press.
I have purple Powerflex bottom arm rear bushes in my diesel Panda, and they are also OK. But they are MUCH stiffer than the standard Panda bushes, which reduces comfort significantly. On the other hand, they do last longer than the standard bushes on the diesel.
Personally, I think Fiat got the 100hp dynamics just about right with the factory-fit equipment - an unmolested one with fresh suspension is great fun to drive and puts a big smile on most faces.
Tired bushes, springs and dampers make it soggy and crashy.
Aftermarket gear usually makes them "feel faster", but handle badly, feel uncomfortable and, in my opinion, misses the whole point of the 100hp. Its a small, light car with just enough power to be fun, with closer ratio gears to keep the driving experience interesting, while still being good for a trip to IKEA for a surprising amount of flat-pack furniture (or a washing machine etc.).
However, that's only my opinion, and it's not my place to criticise what other people do with their cars.
The biggest problem if going the "original spec" route is identifying and obtaining the correct parts, as many suppliers seem to think that the 1.4 Natural Power is the same as the 100hp (it isn't) or that "normal" Panda parts are the same (they mostly aren't). I've found that using part numbers from
EPER and avoiding online "compatibility checkers" is the only way to be sure.
