Helps if I post for the correct car
Lol not to worry, I had a dig around and found it.Helps if I post for the correct car
Ignore me, actually, it looks like the pressure and temperature sensor are part of one fitting and are part K47Lol not to worry, I had a dig around and found it.
Based on the component location I believe the air pressure sensor is part L10.
It’s on the puntoLol not to worry, I had a dig around and found it.
K043 | INTEGRATED AIR TEMPERATURE SENSOR | Op. 1056B54 INTAKE AIR PRESSURE/TEMPERATURE SENSOR - R.R. |
K044 | AIR PRESSURE - TEMPERATURE SENSOR | Op. 1056B44 AIR PRESSURE SENSOR - R.R. |
K046 | RPM SENSOR |
Yep, got it now.It’s on the punto
Just missing on the panda and 500
K043 INTEGRATED AIR TEMPERATURE SENSOR Op. 1056B54 INTAKE AIR PRESSURE/TEMPERATURE SENSOR - R.R. K044 AIR PRESSURE - TEMPERATURE SENSOR Op. 1056B44 AIR PRESSURE SENSOR - R.R. K046 RPM SENSOR
So just out here again.I would go with sorting the ambient temperature
I know it should read from ignition on need to crank
Maybe put the original engines cam and crank sensors back on
Maybe disconnect the injector wiring loom as it will be the only bit not from the original engine
1.2Is your car
1.1
1.2
Aircon
Dualogic
Right hand drive or left
Flyby wire throttle or cable
2wd or 4x4
The wiring is slightly different
I will see if I can find the closest to you original car
Okay let me look1.2
No aircon
Not sure if dualogic
Right hand drive
Not sure what a flyby wire is but it has an accelerator cable
2 wheel drive
Manual..or semi.auto1.2
No aircon
Not sure if dualogic - just googled, it isnt
Right hand drive
Not sure what a flyby wire is but it has an accelerator cable - just googled, if by fly by wire you mean an electronic throttle then no, it's got a cable.
2 wheel drive
Per the diagram aboveDoes your car have these colours wires on the cam sensor
Ignition on
Top CAM sensor
Green 0V
Green black varying 1v - 4V as the pulley spins
White 5V
Yep.Are the colours on the MAP
Black and white
Black and pink
Black and red
Brown
