WildFeraligatr
Evening all
I've posted on here a couple of times about my partners Panda - long story short, I've had to replace the engine because he drove around with a blown head gasket and the old engine is buggered.
I'm at the point now where I'm trying to get the new engine running, and I'm at the stage where the engine will crank with the ignition but won't actually start. There's no spark to the engine - the ignition coils are good, as are the leads and spark plugs, and my OBD reader threw out a P0335 fault for an issue with the crankshaft sensor circuit. I've changed the crankshaft sensor itself, and tested the circuits going back to the ECU, and all are fine. The battery is fine too.
My question is - the ECU worked fine with the old engine but with my testing I can only imagine the issue is with the ECU. Does the ECU need to be reprogrammed or something to align with the new engine? If so, can I take the ECU to an auto shop and get them to 'wipe' it or something? Or is the ECU just buggered and I need to try and source a new one?
Thanks in advance.
Thanks in advance.
