what CPU is it for and what address does the dump start from?I don't have the dump from the 1.4
ECU memory dump from the 1.2 is attached for you to have a play with
But as you can see unless you have purchased the correct software it's useless
Trying to turn a 1,4 into 1.4 tjet is not the way to go in my opinion, but it your car you can do what you want
The tjet is a completely different engine
different head design
Camshaft housing
Camshafts
Forge crankshaft
Different counterweights
Larger flywheel bolt
Pistons
Extra cooling in the crank case
And so on
Without lower the compression the amount of boost before the engine disintegrates is very limited
There's much more information in the punto sections, but don't believe the quoted bhp unless it's been on a calibrated dyno
It's more cost effective to get meaningful power increase to swap the engine for say a bravo 1.4 t-jet
Wait, is that really true? How can the Panda work with the T-Jet Bosch ECU when doing a swap, if that's correct?Fiat configures the Engine ECU, Body Computer, Instrument Block and ignition key chip as a single system. The lock together at first power on. Removing or changing any component will stop everything else working.
The network protocols are the same between the bravo ECU and the 100HP the pin outs are differentWait, is that really true? How can the Panda work with the T-Jet Bosch ECU when doing a swap, if that's correct?
An adaptor is needed to plug the ECU in, the ECU needs to be virgin
Been done many times.
That didn't really answer my question, nor counterfeit the pairing info posted.
If the components pair on first start and "lock together", how come the T-Jet Bosch ECU work with the dashboard?
Fiat ECU boxes (engine, body comp, instruments cluster) all contain a chip (tech term ;-o) that's open when manufactured. When connected into the car and first powered on, they all lock onto the same code**. With appropriate tools, any box can be reset to zero ("virginised").That didn't really answer my question, nor counterfeit the pairing info posted.
** I do not know what code they use, but basically they all become one unit. Fit another used box or one that's not got the code facility and the system simply won't work.
You not got itPeople doing the Pandapter swap seems to buy altered ECUs?
I think you are the one not following along.You not got it
The Bosch ME7.9.10 ECU from the Fiat Bravo or Punto 120/150HP
Is a plug and play solution
The ECU still need to be vigin (wiped clean of the old key information) so when it's plug in it reads and write a copy of the key code from the body computer
Via softwareI think you are the one not following along.
The ECU must be reset to work with the BCM. That is not a simple I/O pin bridging. So tell me how the ECU is reset, or virginised if you'd like, if not people are buying a whiped ECU or buying it as a service.
