One side of each injector should be 12V ignition on not crankingI've just checked the ignition plugs and have no volts there, is that normal given I'm not cranking the engine?
Not the fuel injectors - the plugs next to the coils.One side of each injector should be 12V ignition on not cranking
Same feed goes to coil
this is not correctI say 0v - it's 0 on one side and 0.08 or so on the other
Ahaha - a problem has been found!Measure
this is not correct
Need to look at the circuit diagramI say 0v - it's 0 on one side and 0.08 or so on the other
