Technical Do I need to get my ECU reprogrammed/repaired?
Can’t find the wiring quickly from the right side and convert from Italian to uk. We are loosing the light
One of the larger corner cables should measure a dead short to the injectors and have battery volts on it
Okay - I popped the the battery out to look for this plug so let me pop everything back on.
When you say injectors do you mean the ignition plugs that showed low voltage earlier?
Do the injectors
Each one has two wires
One cable is the same colour on all the injectors this should have battery voltage
F22 20A is worth checking
F22 fuse is OK.
I've pulled out 2 injectors, both have a red/brown wire which is showing 0 volts on both. The other wire on both shows around 1.9 volts when testing at both the battery negative terminal AND when testing at 3 of the 4 corners (point L is the one without voltage per your diagram).
Post here so bothersome to keep looking them up
A Light Blue
B White
C Orange
G Yellow
H Grey
L Blue
M Brown
N Black
R Red
S Pink
V Green
Z Violet
The cable you want is MB brown and black
I'm gonna have to go inside now as I'm starting to be unable to feel my fingers but keen to hear your thoughts.
Missing 12volt here
Sorry when you say missing 12volt, do you mean a component is missing or do i just need to check the fuse?
I'll give the fuse a check but i would be surprised if it's missing something else if it was running ok before?
This one is the correct brown and black
Should be battery voltage with the ignition on
Are you sure both half’s are in fact connected. It’s possible to have been accidentally disconnect while removing the engine
I can’t see the others half tab in the photo
Right - as stated before I have voltage at that wire, but also at 2 of the other corners (the one directly above where you've highlighted doesn't have voltage).
Do you mean are both halves of that plug connected? If so, then they are very much connected as I did try pulling it apart and it was having absolutely none of it.
12V isn’t present at the injectors
Something not right relay, fuse, wiring are the most likely
I suspect the connector D004 it’s selft in the fuse box in my car but underneath
May have got tucked out of the way during the removal of the engine
Great
Until we get battery voltage here nothing is going to work
The connector is a joint. I am hopping it’s the other part hasn’t been pushed together properly
The other part? What would i be looking for there to see if it's been connected properly?
Just been looking at the wiring diagram again to try and understand it - would fuse T09 want checking as well?
Next move would be to separate
This
And see if the corresponding pin the other side is getting 12V
There isn’t enough visible to see if bottom half of the connector is even plugged in
