Old 1 Week Ago   #1
Serbia
Correct spark plugs for 1.1 - 2006
Recently I changed the spark plugs from NGK R to DCPR7E-N-10 (4983) for my 1.1 2006 (January 2016) and car started to misfire on low rpm while accelerating.
Old: NGK R, there wasn't a problem with them.
New: DCPR7E-N-10 (4983), misfire on low rpm while accelerating
Manual: BKR5EZ
Old and new spark plugs differ from those in the manual because of the thread size and gap. There is a big confusion about these spark plugs and I see that many questions are asked on this forum about them. I couldn't get a definite answer.
These DCPR7E-N-10 (4983) are everywhere listed as correct ones but misfire started right after they were fitted. What could went wrong? Can someone help me with correct ones?
Wasgehabendas is offline Reply With Quote Quote
Old 1 Week Ago   #2
Trader Rating: 1
portland_bill has donated!
Re: Correct spark plugs for 1.1 - 2006
Sometime around the end of 2005 or the beginning of 2006 the plugs changed to ones with a smaller thread diameter, on 1.1 and 1.2. This may have happened at the same time as the change from square to round oil cap, but that's just a guess. The handbooks, as always take some time to catch up, mine also states the old ones, although the engine takes the new ones. I've been replacing these annually for the last ten years without any problems. Your new plugs are unlikely to be the cause of your problems.
When you changed the plugs, you did not remove BKR5EZ so that you could fit DCPR7E-N-10. The ones you removed must have been DCPR7E-N-10, or equivalent form another manufacturer.
All Panda and Punto 8v engines suffer from ageing plug leads. They deteriorate, and break down, eventually causing a misfire, which can destroy the coil if left unfixed. They tend to stick to the plugs and be difficult to remove, so at plug change time, disturbing them could be the trigger for them to fail. It might be as simple as them not being attached to the plugs securely. If the plug cover has moved along the cable, the connector may not be secure, or even touching the plug terminal, so the spark has to jump that gap before it reaches the plug electrode gap. That'll strain the coils very quickly.
Are the plugs fitted properly? I have seen plugs that have not been tightened properly. The gasket washer does nto just seal the plug, but is an important part of the heat path to maintian correct plug running temperature. A gasket that is not squashed properly can make a plug run hotter than it should, which can lead to a holed piston. Do not overcompensate and overtighten.
Why did you change the plugs? Was this a routine service, or was there a problem ther already, and is not fixed, but you are focussing on the only new part?
"NGK R" may be a plug type, but is not a specific part number. Whatever they are must have at least been the correct thread size. Perhaps some more detail of those might be useful, and the reason not to replace like with like. Had those been fitted by you, or a previous owner to try to 'fix' a misfire?
If you need help, give us the detail we need.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 1 Week Ago   #3
if you are fitting DCPR7E-N-10 plugs
and the recommend in the manual is BKR5EZ
then the plugs you have fitted are 2 levels to cold, this means the tip will not retain the heat required for optimum cumbustion, spark plugs not only act as a spark producer but also keep the cumbustion temp to a set level keeping the engine clear of soot and other particles.
A cold plug will create a missfire as much as an overheating plug will.
this might explain it
/https://www.ngkntk.in/ngk-technology...of-heat-range/
09 johno is offline Reply With Quote Quote
Old 1 Week Ago   #4
Trader Rating: 1
Quote Originally Posted by 09 johno View Post
BKR5EZ has a 14mm thread diameter
DCPR7E-N-10 has a 12mm thread diameter
Might be quite a struggle to get the DCPR to stay in the head, or a struggle to get the BKR into the smaller hole.
I think the key issue here is why the plugs were changed, and if to cure a problem, why the new plugs are being suggested as the cause.
A low speed misfire is more likely an HT issue, with leads or coils, or perhaps a head gasket problem. Could also be mechanical, with valve seating issues, or piston ring failure, but much less likely on a FIRE engine.
Likes jrkitching, jackwhoo liked this post
Old 1 Week Ago   #5
put the old plugs back in ?
koalar is offline Reply With Quote Quote
Old 1 Week Ago   #6
I strongly agree with Portland bill,
Change your plug leads and see if that is the cause of problem.
If problem still there you may have a faulty new plug, that said I have never had a faulty ngk spark plug.
Good idea from koala too try old plugs if you have them, What type are the old plugs?
jackwhoo is offline Reply With Quote Quote
Old 1 Week Ago   #7
New coils are cheap. Its possible the job finally finished one of them.
DaveMcT is offline Reply With Quote Quote
Old 1 Day Ago   #8
Serbia
Sorry for the late reply I was away for some time.
I did change the plug leads but everything is same, no changes. Mechanic said coils are fine too.
Last time car was running normal was on:
DCPR7E (3932) spark plugs, fitted by FIAT dealer. In the first post I mentioned them as NGK R because I didn't know the correct type.
Difference between DCPR7E (3932) and DCPR7E-N-10 (4983) is the gap - 0.8 mm vs 1.00 mm.
After fitting these 4983 engine started to shake, muffler too, strong misfire at idle, knocking sound from the engine and jerky acceleration and deceleration. Are these things possible from this "small mistake"?
@portland_bill I did change the spark plugs as part of a routine service.
Old 1 Day Ago   #9
Trader Rating: 1
The difference in gap should not cause a misfire, unless it just shows a weakness elsewhere. I would have expected any weakness to show already, and the new plugs to make it worse.
Contrary to popular belief, a smaller gap does not make a better spark. A larger gap requires a higher voltage to get the spark to jump, so creates a better spark to set fire to the fuel. This does of course need the coil to be capable of creating this higher voltage, so just increasing gaps on other engines won't necessarily work.
(In the eighties, with the introduction of the Maestro and Montego, these were the first cars to arrive at Rover dealers needing larger gaps. Many mechanics promptly closed the gaps, creating misfires due to weak sparks.)
The larger gaps take a little longer for the voltage to build, so spark timing is altered to suit. So many variables illustrate why it is important to keep it all as the manufacturer intended.
Changing the plugs is almost certainly not the cause of the issue, it has merely highlighted it.
New leads still need to be checked for correct fitting.
Firstly, are they all on correctly, or is it now just running on two cylinders. Might sound silly, but a simple quick check will avoid lengthy diagnosis. (I did this early this year on mine - wouldn't start at all, but did cough a few times.)
If you've got good quality plug leads, they will be a tight fit over the ceramic. Good in one respect, but can also mask whether the connector has clicked onto the terminal properly. Check this next. Similarly, ensure they are fitted into the coils firmly.
Recheck the coil low tension connectors, and the ECU plug. There have been reports of loose terminals in ECUs. Remove the plug gently, and prod each terminal in the ECU gently to check they are firm. Do the same with the connectors in the plug, and visually check for any signs of burning indicating a poor connection.
A compression test might help, but physical damage is unlikely. A mechanical problem should have shown some symptoms before the service. Was the service done because it was due, or done because there was the start of any running problems.
Was this just a normal service, or has the cambelt been changed this time? If cambelt changed, recheck the timing.
Put the old ones back in. Does the problem disappear.
Who put the wrong ones in? You at the last service, or a previous owner?
Old 23 Hours Ago   #10
The 1.1 is noted for wiring connection problems at the ECU. Faults which look like plugs and coils are one of the issues. Very carefully, check the ECU multi connector and wires going in. It's possible a broken conductor is preventing one coil from sparking.
(T) Correct Spark Plugs thuraja Panda 5 16-08-2015 20:15
(T) 2006 Panda Spark Plugs Bobfreeman Panda 2 10-02-2013 09:55
(T) How to change spark plugs in a doblo 2006 1.3 diesel kingabs Doblo 8 11-05-2011 12:52
FAO tom...spark plugs. bosch plugs or these..... Paul R FIAT Boo Archives 10 16-04-2005 00:07
correct spark plugs? burno FIAT Boo Archives 7 17-11-2004 19:17
