It's possible but unlikely to be the actual fuel itself
The fuel ignites easy, so should work as a vapour
It was nearly empty when it topped up from a jerry can
It ran for a further mile
A small amount of fuel percentage wise will not stop the car running
It now been emptied and four cans of good fuel
It runs on easy start, we probably don't need to look at the ignition
I also found clumps of something covered in oil on the tip of the breather opening next to the solenoid coming from the rocker cover.
Not sure I understand what we are describing here
At this point, I could only get it to turn over (before cutting off seconds later) if it had been left for some time (hours).
I assume the battery is now flat
That is the latest report, yes.
I know what been written
There seems to be mixing between
Cranking
And
Firing
Cranking turning over weerweer sound
Firing, engine running
Or is it both cranking and stopping
Running and stopping
Is the oil light on at ignition on
Is the battery light on at ignition on
Is the engine check light on at ignition on
Is the immobiliser off at ignition on
Does the battery and oil stay on when you start to crank
Whoo
Missed this is this on the rev counter, are you sure this is correct
"would say it goes to about 500 then 300 rpm"
500 rpm is way faster than normal on a standard size battery especially if it been cranking a bit, possibly low compression from a slipped timing belt
