thing is, it always does sound better after an oil change![]()
what about 6k though, when selenia was used never noticed any difference pre or post change.
one thing i have noticed is that the mobil 1 is staying much clearer than the others
car lube i use, cos its like £12 for 5 litres of 10w 40 semi synthetic.
I've only used Halfords wipers once, about 15 years ago and never again. They were on the car for a week and I ripped them off and threw them away. Only ever use Bosch now.
Would you put Halfords oil in your car?
Yes, but I'd put it in a bin bag or similar first in case the bottle leaks.![]()
We all use cleaned and re-cycled oils, the oil itself does not degrade and it's just cleaned and has new additives put in to get the performance back and then back on the shelf.. I know Beany is fretting about his turbo bearings failing... so it makes sense he uses something that to the best of knowledge gives him a fair shot at success.
Would anyone use "cleaned and re-cycled" oils....?
What brand of oil you use is not a black and white issue, I usually use the cheapest I can get with the correct API grade*, however Comma semi synthetic made the Tempra TD "diesel clatter" a lot louder, I can only guess this was due to some volatile fraction getting past the rings. Changing to any branded oil such as Esso or Mobile fixed it. For the Marea and MG I use Comma or Halfords or a branded oil depending on the deal. TBH making sure you simmer the turbo after using the car will have more effect than choice of oil, I had no turbo probs using the Comma and I always used to let the car idle for a short time before turning it off.
* in fact for both my cars I can get a grade better than the minimum without paying a fortune.
not really it can be burnt to make electricI wouldn't be suprised if all oils have a percentage of recycled product in them. They must do something with the millions of gallons of oil removed from vehicle lubrication systems each year - and recycling it would make sence if it's cheaper than the whole process of extracting and refining new oils.
Would you **** in your petrol tank?
Ok the car has the halfords fully synthetic 5w40 in it now, and its soooo much quieter from cold! doesn't sound like a tractor anymore lol and it seems to respond a bit better too but thats possibly just because the oil before was a year old.
(only just realised the garage didnt give me back my bottle of oil! Should still have 2.2litres in it! going to give them a ring in the morning! )
