I was rereading some of this thread yesterday and one of our contract engineers was in the office.
He builds and tunes stock cars and track cars for himself and others.
He pointed out if everything is even, the MAP reading will be even.
If all cylinders are all equally good (or bad if the timing was out), the MAP will read steady.
(We obvious need to trust the MAP is good though)
As you can see in first image below, the "good" graph Koalar posted, the reading is steady.
If one cylinder is off, say a broken valve spring, bad valve seat etc, the MAP will drift. It will try to push up.
How much depends on how bad the issue is, but as each cylinder drops, the iffy one won't pull the same and cause it the MAP to drift.
You can see in the second image, it's drifting up.
(This one was because of a broken valve spring)
The inlet pressure will pulse, but the pulse average should be steady and not drift.
We discussed testing this out and he reckons a drift will be easier to spot with a crank test as the crank speed will be lower and the pulses slower.
Though going direct to a compression or leak down test if you had the kit would tell you the same thing.
To do a crank test.
Make sure the battery has good charge, pull the fuel pump fuse and run the engine until it stalls.
Log and record the MAP while you crank the engine over for 8 seconds or so.
It would be better to try and log it as a graph, as it will be easier to spot any meaningful drift.
Also without the engine firing, you aren't producing a load of hot, expanding exhaust gas and sending all that down the exhaust through the Cat..
It's just pumping the air it's sucked in, which is a lot less that that expanding hot gas.
So if the Cat or exhaust was partially blocked and your high MAP reading was because all the exhaust is backing up, taking all that expanding gas away should show if the MAP reading drops towards expected value.
