Technical  Loud tapping when starting up
Chiddleston
My Fiat Panda MyLife 1.2 has developed another problem, but two in 6 years isnt bad, hopefully. Starting it up, whether the engine is cold or hot there is a loud metalic tapping noise. From the cabin it sounds like a 70's VW Beetle, but with bonnet open its like someone tapping the engine top with a hammer. Press accelerator the tapping gets louder, but leave it idling for a few minutes the tapping isnt too loud, theres also the occasional drop in revs for about a few seconds but not enough to stall. It usually stops after a minute or so and the car will run perfectly well until turning off and restarting.
Anyone know if its this likely to be needing valve adjustent? or tappets? neither have been done before, mechanics never bothered doing them when in for a service. Car had oil change and service end of last november, has just passed 100,000 miles and due a new cambelt at around 105000 as the previous owner had original changed at 35k.
Morning.
Sounds like a worn camshaft lobe to me,
If your planning to do the cambelt soon then if you take the cam cover off in advance you will see if you need to be addressing the camshaft at the same time.
Tim
Does the 1.2 have oil filled cam followers? The ones on my (yes, I know it's different) 1.3 diesel were badly worn on the ball-ends. Some were falling apart before the chain broke. I found needle rollers in the sump.
Cars a 2011, 61 reg. 1.2 engine. Fluids are all OK, no water or oil leaks or excessive usage, Spark plugs were new in november, have pulled those again and all OK. Its done 5000 mile since last oil change. Not sure about it being the camshaft, as theres no misfire at any speed but then, im no expert.
Have a compression test done, might save a lot of wasted time
Or post a video as noises are difficult to describe
Sounds like it's gone between cylinder 1 and 2
Normally sounds worse under heavy acceleration and clears up when warm, metallic, sharp, tapping
Revs drop and pick up at idle
Moisture on top of the throttle body
There quite a few reasons for a knocking noise at start up. You can work through all the possibilities. Which is time consuming. Or confirm or eliminate one of the most likely first
Has the cam belt degraded to the extent that it's slipped a couple of teeth and the pistons are just nipping at the valves creating the noise but not enough do any damage.
Yolander makes a scarey suggestion. I would check this fast. Valve clearances are not traditionally adjustable. Set by shims and I was told here its .unusual for these to require redoing. I had one of ours done at about 50K and they were still perfect. If oil is bad you will certainly hear this on start up. I used Petronas Syntium and it was awful. So bad I think it was not genuine. Changing the oil for Castrol edge stopped all the rattling stone dead. I agree visual inspection of the camshaft is also a good idea, You can set it TDC and see if the cam is correctly aligned. This will assist with a belt check. Check the cam and the clearances while the cover is off. Could be a small end but that would be noticable whatever.
Unlikely to be timing belt
As its fine after it's warmed up
Lots of things it could be, sticking valves and so on
But here what a a blown head gasket can sound like
Normally goes away when the engine as run for a bit
As its fairly common I would eliminate it
Then move to other possibilities
Here's mine
And an example of the noise
Stupid me
Here mine and forgot to post the link
Mine was Identical to the noise in the video
Video would help a lot especily if you move the camera around
We would be able to tell if the sound is from the top left right front or back as the microphone is very sensations to distance, more so than your ears
Also does the sound alter with gear or change if you press the clutch
The drop in revs points to an engine problem. But if a coincidence (unlikely) it could be just about be anything connected to the engine and spinning
