Technical Rattling noise in certain gears
unfacedman
Hello world!
All of a sudden, a strange rattling noise started to appear when the third gear is engaged. But only when I release the acceleration pedal. At the slighted touch of it - the noise stops. Also when I disengage the clutch - no noise.
That was easy to diagnose. A bad synchronizer, isn't it?
Well, not so fast.
One day after the noise has begun, it spread itself further.
Now, the noise appears at the third, 4-th and 5-th gears, and even when I press the clutch pedal!
Also, if I put the transmission on neutral - after one of these gears, the noise still appears, and again, even with pressed on clutch pedal.
Disappears only when I press the accelerator.
First and second gear - no noise.
Sounds like a bearing inside the gearbox
My guess would be the input bearing
I had a couple fail but the symptoms only partly match
I can't see any option except dropping the gearbox and examination
@rmjbn1
@irc
Looking for oil inside the bell housing would be my first step
There's an inspection hole at the top
Thank you for your reply!
Wouldn't the input bearing rattle at all speeds?
Also, shouldn't it stop when pressing the clutch?
The plastic cage can break up
They normally rattle more when the gearbox is not under load, they get worse and more noisy as time goes on
They definitely rattle in neutral
As above, worse under light load, rattles in neutral.
I did have one which had no detectable oil leak into the bellhousing, but when removed the shaft could be moved a couple of millimetres left and right. But usually there will be an oil leak and clutch will be "grabby".
My failed input shaft bearing was definitely rattling in neutral.
But the noise stopped with clutch depressed as the input shaft stops turning.
Is it still rattling when stationary with the clutch down?
Unless your clutch is also dragging? Any difficulty selecting a gear?
I couldn't really hear the rattle once on the move, too much other noise going on.
But the car was much quieter with a new bearing.
Mine also resulted in a failed input shaft seal and a coating of gear oil inside the bell housing - as koalar says easy to identify with a finger through the inspection hole.
The research continues...
(rmjbn1 - no, no noise at all when stationary. Strange, innit?)
I found an empty, long road downhills, and turn the engine off. Started to slide down with no engine revs/clutch spinning at all.
When I put the trans into the third, surprise! The noise emerged again, and was keeping even when I pressed the clutch pedal to disconnect the trasmission from the turned off engine. Even when I put it back to neutral.
I would have suspected the noise have something to do with the driveshaft/wheel bearing, it doesn't make any sense why, in that case, would it appear only in certain gears engaged!
Another funny thing - upon smooth, even terrain like parking lot floor - almost no noise, if any.
That's really odd.
No noise at all when not in move.
I know what bearing noise is like. Something should be heard even in idle\stop with gear engaged (while the clutch is disengaged, of course).
I wonder if for some reason the shifter doesn't push the 3-rd all the way to the end. If it makes any sense to adjust shifter's cables. There are adjusting nuts on them.
That doesn't really match with input bearing failure.
Have you checked for oil leaks? Driveshaft seals?
Those symptoms sound more like a gearbox with a few different problems, and that can point to one which has lost most if its oil and is gradually trashing its internals.
Could it be the tie rod ends? Take a look, is there any play? Or maybe deformed cv joints?
The gearbox bearing is impossible?!? considering you hear it when you press down the cluch. Isn't it? Is the cluch working good? Does the clutch cylinder push the fork all the way? Might be the clutch bearing maybe...
The gears are still spinning, back driven from the wheel
This is why Synchromesh was invented
And why you need to wait until the wheels stop before it's possible to engaging reverse
There no noise while stationary
And noise in 3rd 4th 5th clutch up or down when the car moving
Specific to which gear is selected, and getting worse, I'd be surprised if it wasn't in the gearbox
Would still be my first check, 10, 20 seconds
Followed by
Sounds plausible
It's had an oil leak
And also a broken bell housing
It's pretty hard to damage the bell housing unless something internal tries to escape
Here a loose input ball bearing made a attempt for freedom via the differential
Yeah, that was a long old story ago... fixed it since, of course.
Replaced the bell, the bearing and the seal. Everything was fine for two years, and now...
A friend's Honda Jazz was quite while driving and shifted gears just fine. But the rattle in neutral was obvious even with windows closed. Put the clutch down and rattle stopped. It was the gearbox input bearing.
I had a BMW motorbike that was developing the same issue, but apparently they all did that after a while.
Wife's 1200 had a new bearing and oil seal when I changed the clutch. It's a bit of a faff, but the old bearing had been run dry so needed to be changed. Later models have a bigger bearing that's not shielded by a large gear up against it.
