unfacedman
- Joined
- Dec 26, 2013
- Messages
- 30
- Points
- 61
Hello world!
All of a sudden, a strange rattling noise started to appear when the third gear is engaged. But only when I release the acceleration pedal. At the slighted touch of it - the noise stops. Also when I disengage the clutch - no noise.
That was easy to diagnose. A bad synchronizer, isn't it?
Well, not so fast.
One day after the noise has begun, it spread itself further.
Now, the noise appears at the third, 4-th and 5-th gears, and even when I press the clutch pedal!
Also, if I put the transmission on neutral - after one of these gears, the noise still appears, and again, even with pressed on clutch pedal.
Disappears only when I press the accelerator.
First and second gear - no noise.
Well, not so fast.
