If the timeing Could be out 180 deg , Change the two plugs on the Ht side , of the coilpack , and see if it runs ..
			Andi_F said:Well done Mark.
So Cinq fires again... how long untill she's back on the road??
gengis said:That's good you got it running...as far as the oil supply to the cam is concerned, try taking the pipe off and make sure the oilways are clear. Not too familiar with these engines, but does the feed pipe come from the centre bearing housing then go left and right along the cam? If so the oil would come up through the block pass thru the cylinder head gasket, thru the cylinder head, and on to the feed pipe.
So is the oil getting passed the cylinder head gasket? no blockages with rtv (if used) or is the gasket the correct one or the orientation correct. Is there a dowel in the block to line up with the cylinder head, which would be the gateway for the oil supply to the head? Is there oil leaking from the cylinder head? Is the noise a multiple tappet noise or just restricted to one or two rouge wide clearances?
Just a couple of things that come to mind...best of luck.
Mrcento said:seriously, i need light in my garage, people with lit garages don't know how luck they are! :laugh:
