Technical  Petrol pump removal
What position do I set the multimeter to I'm a complete novice
Ohms or if the MM is autoranging then you don’t have to set it if not try one of the ohms settings until you get a reading.
Thanks koaler and when I'm testing the pump /float where does the other end probes go there are 4 points where the block feeds into
Thank you I will reply tomorrow with results (if any)
Morning mate did the test yesterday and the old pump/sender is working fine as you said they rarely fail something like 40 20 empty so in summary the old pump and the new pump are giving exactly the same readings to the petrol gauge. Do I go back to the tank to make sure the float isn't catching on anything because I put it back in the exact place it was originally in there isn't much scope for rotating it as the fuel pipe hasn't got a lot of play or do I start looking elsewhere thanks once again for your help
And moves slowly in time to moving the float..?
I haven't tested that but when I turn the ignition on the needle does rise slowly up to 1/4 then stays there until the petrol starts dropping then the needle starts dropping. The actual pump sender is fine and working correctly
