Technical Petrol pump removal
With the old pump
Float up you can sellotape up
Pins 5 and 6 the small ones
What was the ohms reading on you meter
Is it close to 33 ohms
With the old pump
I posted somewhere this morning it was close to 40 then moved float down it we t to 20 then at the bottom zero
Mmm possibly a decimal point missed or bad contact
This is measured disconnected and at the pump connector
Should be roughly
Fully up should be 30 ohms
Full down should be 300
Should be roughly
Sorry it's all wrong just got my son to help me and this is weird empty 298
Full 35
Middle 174
Empty 298
Great
35 is correct
Tape the float in this up position
Pug it into the harness
Switch the ignition on
Don't worry the motor will spin for about 3 seconds only and switch off
Wait, the needle will slowly rise, give it a good 30 seconds to settle, what the highest it reaches
Great
35 is correct
Unfortunately my son put it all back together so unable to carry that out
Connect the car's wiring to the old pump. Keep the floater up and turn the ignition on (not crank). Where does the needle go? And when you let the floater easily down, needle does what?
Koala mate we did as instructed plugged the old pump in put the float to the top switched on ignition position 1 the fuel gauge went up to full then we let the float down to zero nothing happened it stayed at full we turned the ignition off moved the float to halfway switched ignition on gauge went to half moved the float up it stayed at half so wherever you put the float it goes there but can't be altered so the gauge is functioning
