Cinquecento Emma's Turbo Progress Thread!
Hey, as some of u may know my turbo cinq is in the middle of having an engine rebuild by my dad. This is the progress so far, and will add to this thread as things happen.
So far......
Port and poilsh and a bit of boring out nearly finished
gaz_wrexham said:
i cant stay out of this thread any longer, i been trying to cause im really jealous and want one :p
very good work (y)
i like where the air filter is, have you sited it there for any particuler reason?
Yes its there for maximum air flow, plus its a straight line from the turbo.
em
Alex22 said:
Vanaaken quote around 104 bhp...
But i sure with a bit of tinkering its poss to get around 110-120 bhp out of them.
Figure quoted on paperwork for mine was 102 :)
low boosters are 85-90 bhp iirc :)
Emma, i'm well pleased its all come together! :slayer:
I'm close to vanaaken if u need any bits picking up ever (y)
Yes thankyou, it has all come together nicely, when is yours going to be ready :p ?
Mini update!
Taken turbo cinq for a test drive round the block, seems to have a slight brake problem. Turns out to be a sticking handbrake cable, so waiting for fiat to get the part in, can't believe its not in stock:rolleyes: Will be fixed on wednesday and MOT'd on thursday.
PS does anyone elses cinq have a long brake pedel?
emz
foxyemx said:
Mini update!
emz
Compared to a short one? :p
Jordan
:eek: That was fairly naff, sorry....
foxyemx said:
Mini update!
emz
As in long pedal travel?
foxyemx said:
Yes, the whole system has been bled and it still feels awful. My dad said might have to change the master cylinder, But luckily we still have Aaron's red wrecked car so can get that one and try that.
There will be longer pedal travel from using the standard cinquecento master cylinder as you're pushing bigger pistons, but not to the extent you're describing.
Mine was similar though, i wound the pistons in and out a couple of times then re-bled the system and that seems to have sorted it mainly. Also it bites alot better now the disks and pads have bedded in. But still not as firm as what it was like before :)
If you pump the brake pedal a few times it goes nice and stiff rigth from the top though, due to the vacuum assistance. Mine doesnt really bite till about a 1/3 down the pedal travel normally
