2007 1.2 Dynamic.
How easy/difficult is a timing belt change?
Any special tools required?
I can't find one, is there a walkthrough anywhere?
Thanks.
is it a 1.2 8V petrol ? if so will be simple and there is a guide for it somewhere on here
you will need a few basic tools
timing marks can be hard to see but if you get it wrong it wont do any damage
has the belt gone or are you replacing as a caution ?
if belt still intact you can use the marking method,
remove aux belt pulley and get a paint pen mark the timing belt and pulley with a line on both camshaft and main shaft pulleys, then remove belt and holding new belt next to old one transfer the marks onto new belt, fit new belt up to same marks on pulleys
adjust tensioner and should be ok,
someone will post more info or a link to a page where its been explained fully
not quite as simple as that but
