Technical  battery light staying on
boothy99
huddersfield
battery light coming on after driving a minute or so, also intermittent problem with power steering , going heavy then returning to normal. think i've see na previous thread somewhere saying it's an electronic power steering fault, put a new battery on about a month ago so don't think it will be that though the stop start still doesn't work
The battery light is intended to tell you that the alternator is not charging the battery. If that is the case, the steering will go heavy, as it demands a high current.
A steering fault will not illuminate the battery light.
A common fault is the main battery earth cable, from battery, to body, then onto gearbox. These corrode internally, so can look fine, but struggle to pass current. A failure of this will cause the issue you describe.
It could of course be a simple matter of the alternator failing.
If after a normal start, the battery light goes off, but then comes on again, I'd be leaning towards the cable as the problem. Does the light illuminating coincide with any gearchange, moving away, or other action that might cause the engine to move on its mountings? That would definitely point to a cable breaking internally.
If you have access to jump leads, put one between the battery negative terminal, and the engine. If the problem goes away, the cable is at fault. A voltmeter across the battery will show if the alternator is charging. Should give around 14v with the engine running. If not, wriggle the earth cable, (under the battery, so be careful not to touch anything moving, or hot.) If the voltage changes, that again shows the cable as the problem. If the cable if fine, the alternator is the most likely problem.
The main power cable could be at fault, but this is less common. Check all connections, and inspect for cleanliness.
Ignore the power steering, if the the body computer isn't seeing a charge it will switch off the power steering to preserve what's left in the battery
So let's fix the charging first
When the engines rpm are over 700 the body computer again starts to monitors from D+
If it goes below 5.5V it will tell the dash to put the light on
D+ and battery charge should be the same when the engines running
Just had a new battery a loose or dirty battery terminal is likely
But there's lots of other cause,
Bad alternator
Bad Wiring
Loose wiring
Body computer
Slipping belt
Just to name
I would start with undoing the battery cleaning inside the terminals and battery post with a green scouring pad a
Visual inspection of the alternator case for crack, especially if you driven through deep water recently
Visual inspection of the earth on the gearbox
Visual inspection of the aux belt
Wiggle the earth and thick red leads and see if the light cones on or goes out
Do you have a test light, multi meter
Bad alternator
Bad Wiring
Loose wiring
Body computer
Slipping belt
Just to name
this is in the mk 3 section & it is a twinair
Unfortunately the twinair is post 2012 so a mk4 on this forum
Anyhow except for the start stop they are very similar charging circuits so run on here if you want
Help for the start stop might be limited here though
I don't have access to the latter wiring diagrams
Bad alternator
Bad Wiring
Loose wiring
Body computer
Slipping belt
Just to name
hi. thanks for the reply, i cleaned the terminals up when i changed the battery.which was around about a month ago & this problem started saturday. if the computer was detecting low charge would it not stop the power steering functioning all the time? or would it be intermittent like mines doing. i connected a jump lead from the neg terminal but struggled to clamp it directly on the engine the best i could do was the bolt for the engine mount but the mounts alloys so it probably wasn't earthing. i.'m taking to my mate who's more au fait with the electrical side & he has a multi meter so we'll se what that brings. i'll let you know the outcome. thanks again john
Bad alternator
Bad Wiring
Loose wiring
Body computer
Slipping belt
Just to name
Sorry to chip in, and it's probably blatantly obvious, but what do you mean by D+
Not uncommon to have issues, change the battery because its easy.. then get to the actual problem a few weeks later.. weve all done that
What was it doing A MONTH AGO that made you swap the battery??
Probably help to explain where we are now :)
D+ is the little wire connects directly from the alternator to the body computer (BSI)
At igntion on the BSI has 12V floating but the alternator acts as a pull down resistor (through internal resistance to the case) pulling D+ to around 1V (has to be below 5.5V) this tests the wire and if above 5.5V it puts the dash light on
When you start to crank the D+ is sent 12V (actually current) this is to excite the windings and start the whole charging process
When the ECU detects a crank speed of above 750 Rpm power is cut and D+ just follows B+ (the big red cable)
The BSI still monitors D+ and if it detects below 5.5V it switches on the dash light
Depending on the BSI software it can shut things down so you can get home or to a garage
Bravo diesel for example shuts of the glow plugs and EPS if an error is detected
Only when less than 5.5V is detected on D+ or above 5.5V at ignition on
Loose wire, chaffing wire, faulty alternator, slipping belt and other can cause intetmitant
There's a handy bracket on the gearbox that holds the gearbox sector cables, blow the coolant bleed screw
yep
What was it doing a month ago..??
Poor starting..PAS failure.. something else..??
hesitation when hot which can become quite bad resulting in the car feeling as though it's losing drive then picking up again search the threads i suppose being two cylinder it could be a misfire, i've changed the plugs & coil packs no different , it was the original battery so & stop start wasn't working so i thought i'd change that as a precaution. possibly the wastegate problem but struggling to get the front nut off the heat shield to check it. other than that it's perfect lol
just going to put this in the latest panda thread as i thought my model was a mk 3, out of curiosity what's the difference between the two & three?
This forum has a strange mark numbering system for Panda. To most people, Mk1 means the small flat windscreen type from 1980s. That makes the 169 a Mk2 and post 2012 a Mk3.
The forum has tried to be clever but resulted in no end of confusion.
Why they could not have used Mk1 and M1a is anybody’s guess. It’s done with Punto Mk2/2a after all.
