General  Boot light
General  Boot light
Yes
If the car has remote locking
The wiring is already in place
And it's plug and play
Its the same lamp unit as fitted as standard to most puntos
If the car only has central locking, the boot wiring hatch handle are different and it's not straight forward
Thank you koalas trying to fit one to mine with no remote locking.
Not going to be straight forward unfortunately
Wiring in a separate fused power wire with a switch on the centre consol would probably be the simplest solution
The original uses the body computer to switch the light on and off, and it's missing some components it used to detect the hatch has opened or closed, on cars without remote, and it not straight forward to retro fit them
My 100HP had a boot light. 1200 Dynamic and MultiJet do not. They all have central locking.
All the wiring is in place and a hole already cut in the carpet, if you want to add a boot light to a car with central locking it's plug and play as in post 2
Only higher spec cars have it fitted as standard though
I'll have a look though with a better quality light. A ballasted LED should be good and not upset the can bus.
Fitted as standard to most puntos, that what I used from the breaker's
Filament bulbs do get quite hot for little light output
L,E.D would be a good choice, but will need to be the proper resistance otherwise it might not shut off straight away
Which indicates the car is cheap. I mean - a drop-in-mountable LED lamp will set you back 3 Euros - including p&p from China.
I know, because I got mine from AliExpress. So cheap I bought two.
As said, drop-in-mountable LED assemblies are available. These do get hot as well. Oddly, as LEDs are known for being very efficient, so I suspect the assembly contains a load resistor, making it look like a filament bulb to whatever piece of electronic gear that's monitoring its health.
One advantage with a filament bulb is the light colour. These LED devices are cold to look at.
