Except the notch cam sprocket lines up with is in the alloy of the headit looks Good to me
Post pictures of cam shaft lobes number 1 cylinder and number 4 cylinder.
It is possible that someone has bolted the cam sprocket to the cam shaft in the wrong place breaking the key between the sprocket and camshaft.
Though that is unlikely because there is no reason to loosen cam sprocket bolt on your engine.
it looks Good to me
You don't have to keep the marks aligned while tensioning the belt just rotate crank twice after tensioning and make sure marks line up again.If i do this , then the flywheel does not remain at zero
If you have slack in belt on right hand side before tensioner is set then marks won't be aligned afterwards.
You don't have to keep the marks aligned while tensioning the belt .
Hi Johno,Sorry, I don't agree with this statement.
When I changed my cambelt recently the crank was 15deg behind the cam due to this kind of false statement, the crank and cam MUST be locked in position when tightening the tensioner pully or the valves will open out of phase which means losing compression on the compression and power stroke early. potentially burning valves etc as well.
By the way now my crank to cam timing is spot on , the engine is running the smoothest it has ever since I have owned it.
I think we are agreeing.Nobut I am a mechanical engineer and engines are my brad and butter
the crank and cam must maintain a direct relationship when set up.
Did you check that the cam sprocket is bolted to the cam shaft in the correct position, there should be a slot in the camshaft that a bump (key) part of cam sprocket goes into before the bolt is tightened. Sometimes the bump on cam sprocket is broken off the cam sprocket, then although the sprocket alignment mark is correct with new belt the cam shaft is not in the correct alignment.No engine codes at all , but fuel consumption is still 10.3 litres/100 km
Oooòoo shoot but thank you for reminder.I think you will find it has,
Or how did I set my engine up?
you have to remove the cam cover and insert a bar with an angle plate into the slot on the camshaft by cylinder 4, the crank is locked with a tennis racket shaped plate that bolts to the crank pully and held at the lower cover securing bolt.
cam and crank are locked , you only then need to worry about ensuring the cambelt from cam to waterpump and crank is tight before tensioning on the 'lose' side.
by tensioning without the locks in place you risk crank and cam timing from going 'out of phase' I have seen this on a MC with devastating results due to the interference aspect of that particular engine.
As the OP is still suffering the fuel issue, what is the harm in doing the job correctly?
DO NOT LOOK FOR KEY ON CAMSHAFT SPROCKET YET.No engine codes at all , but fuel consumption is still 10.3 litres/100 km
