a you say both on 1 & 4 the gasket shows signs of damage, but is that enough ? I don't know, I was looking for something more than that, thought hat was only water jacket sealing, nothing appears between cylinders going out
can't see any damage on underneath of head gasket, photos of thermostat show muck in the holes of the case, (re they bypass holes ?) in the rocker box side I found what looks like broken rubber off valve stem seal, really don't see why I got those compression readings as nothing looks that bad,
did it "overheat" / go HOT.. or just die at the side of the road..??,
the 8V engines are easy for a Head Gasket change, bolts are re-useable,
so it's a £10 / £15 job,
I've never skimmed one yet,and always holds fine for the years I keep the cars :worship:
TBH do the timing.. as I've no reason to suspect anything other than poor timing will lead to a "backfire"
the 8V's will run acceptable @4 teeth out of time..,
but not run at 7..!!,
been there done that
Charlie - Oxford
just looking again at the gasket, you're right it is rusty, also with gasket off the block all show signs of rusty marks, I was looking at the cylinder metal seals and think they are ok, but now looks like head gasket was gone, but anyone else's view please,
looking at the head, it will need skimmimg, there is corrosion around a couple of water holes, and raised areas around 2 of the cylinders, I don't know anyone locally who skims/recons heads so it looks like ebay at £160, as lad needs car next week, not sure what to do, buy a secondhand car, or fix this and get him insurance on my car so he can get to work next week,
right took the head off,
photos attached, can't see any damage that would cause the compression problems, the is damage to cyl 1, but it looks old, not taken head gasket off to look underneath, but cyls look clean, and no movement side to side,
couple of problems lead me to think head needs working on, some large bits of broken rubber stem seals, can't see any oil inside inlet/outlet ports, but it got on the plugs somehow, (2nd compression test) . there are defined ridges on the cylinder head around the pistons & piston sealing ring on the gasket
the water inlet at the end of the inlet manifold has melted as well
