In the beginning you said the "engine sounds louder" and "throttle response is not good". This implies it was better before you did something to the engine. And you had yellow spark plugs which I think means lean running. Perhaps there's no issue with your timing and fault is something else.
Can it be a bad Map sensor ? Or bad O2 sensor ?
