All I need now is new track rods so I can get the tracking sorted.
you should have done that first. once tyres start to wear unevenly they stay like it even after tracking is done.
I did when the tyres were fitted.
Garage says its perfect at 0 degrees both sides and needs no adjustment. the rears are also correct. They are good outfit, but nobody told the Panda so it's still pulling left.
DIY tyre fitting has to be properly hard core. :worship:
A good styrup pump is far easier and quicker than a foot pump. This one has two stages, so could also be used on high pressure bicycle tyres.
https://www.ebay.co.uk/itm/Motorcycle-Moto-GP-Track-Day-Tyre-Pump-2-Stage/122593433507?epid=9016999202&hash=item1c8b2357a3:g:k10AAOSwGYhcACY~
All season..
Surely they cannot be super squidgy compound like winters..?
On a side note.. cracking on relatively fresh tyres seems to be on the rise..
Production changes?
Or is it environmental pollution..??
CO levels are now at a 12 year high..
The heavy diesel engine and low profiles were a nightmare in snow (and I've been driving daily in the NE of Scotland without a problem for a long time and through some pretty bad winters). I could not believe what a difference dropping from 17" to 15" made as well as the different tyres. Plus I don't worry about bumping the cheap steelies over potholes as winter progresses![]()
I do regularly think about buying a small car with narrow tyres as a winter substitute because they're so much fun and can pretty much get everywhere in my experience. :idea:
On a side note.. cracking on relatively fresh tyres seems to be on the rise..(
From what I've seen the tyres are the important bit, obviously the bigger and heavier the car the more work you are giving them but while researching my purchase I did watch several tyre tests.
One of these put 16 205/55 winters against 17 215/45 and 18 225/30. I was surprised by how little there was in it. The smaller tyres had a small advantage in snow and ice but this was reversed in wet and dry handling.
When we were young, starting our family and very broke all the time, I bought a Citroen Dyane. (MOT failure on king pins - remember them?) Working on it required a lot of "thinking outside the box" but it was a good purchase, very cheap to run and I ran it for a number of years.
At that time we lived in a wee village up in the hills south of Edinburgh. The snow could be quite deep in winter and both approach roads to the village were up steep hills. When the snow came the Citroen was the only conventional (ie non 4 wheel drive) vehicle which would regularly get up the hill. I think it was the combination of very thin tyres - 135 SR 15, good ground clearance and a flat floor pan, and an absolutely gutless engine which reduced the possibility of wheel spin. I have many fond memories of that car and, like you, harbour a "secret" desire to own one again - just for fun. Maybe an Acadiane this time?
Interesting. I go from 205/45/17 to 185/55/15 and notice a big difference but how much of that is psychological is hard to guess. Probably a lot more than I realise. Still, it works for me and the steel wheels are a fraction of the price of the alloys so the peace of mind of not worrying about potholes also helps![]()
