Technical  Water in doors
Hi all,
With my Bravo I'm having a problem with water in the doors. I have to move the bottom door seal to drain the water out.how can I stop the water getting into the doors??
Should I replace the external window seals or is the problem something else.
All help appreciated.
Many thanks
Andy
No mate ,sorry
But every time it rains I have to drain about 1 to 2 litres of water out of each door
It sounds like your door drains are blocked. I had this issue on my Bravo. After cleaning with a bit if wire it stopped. Water will pass through the doors but should drain harmlessly away. Road dust, bird muck and little leaves and algae etc build up over time. You may just have to remove the door trim and get access into the door if its very bad. My drain holes seemed pretty small and thus easily blocked.
