First of all, a big hello to the community!
Apologies for my first post being asking for help, but the problem I'm having has me completely stumped and is rather urgent.
My name is Nick and I recently purchased a 2005 Peugeot Boxer, which is essentially a rebadged Fiat Ducato (typ. x244). The car had been reasonably looked after mechanically and the guy who sold it to me had it for over a year with no issues at all. I also need to mention that the car has a Cobra aftermarket alarm fitted which works ok.
As soon as I got it I took it to be inspected and serviced and the mechanic said it was generally fine. About 10 days ago I went to a shop to run an errand and when I came back about 10 minutes later I came across a very bizarre problem. When I turned the key in the ignition the indicators on the dashboard jumped around a bit and a long buzzing noise was heard from the hazard lights switch on the dashboard. The ignition went tik-tik-tik and the clock reset itself.
It definitely sounded like a dead battery, but it was weird that it would go just like that from one moment to the next. Thankfully a service shop was close by and I managed to get them to come over with a battery booster. When we hooked it up, the car started up immediately and run fine.
The next day I went to get a new 100A battery (again the car was starting without hesitation all the times), and I installed it making sure to clean and tighten the connections to the poles.
I thought that was that but I was sorely mistaken.
Yesterday morning I started the car perfectly fine, went to work, stopped for a moment to pick up some supplies and when I tried to start the engine the same thing happened. A loud droning buzzing sound came from the flasher unit on the central console and the car refused to start at all.
The fuel pump is not priming, the engine is not turning at all. The key turns in the ignition but there are no lights on the dashboard, except from the clock which resets itself.
Even more bizarrely if I activate ANY light (eg. cabin overhead spotlights, hazard lights etc), the buzzing sound from the flasher unit starts again and only stops when I turn off the light. Worth mentioning that after a while the continuous buzzing has turned to a waning buzzzzzzzzz which dies out after a few seconds.
For the life of me it seems like the flasher unit is preventing power from reaching the ignition/dashboard etc.
I have experience in mechanical/electrical issues having rebuilt several motorcycles, but not so much when it comes to cars. I know that the hazard lights switch is housed in a small electronic unit which holds some relays and I do suspect that one or more of said relays might have met their maker.
I also know that if you remove that electronic unit, you have no turn signals and/or some other lights, but could that unit be wired in such a way that if it goes, the whole car is immobilized also?
To anyone who has the same model: Can you start the car with the flasher unit unplugged? Could anyone please check if it's not too much bother? The console comes out very easily: a few torx screws and it's out.
Here's what I've done so far:
- I measured the battery and it read 12.5 v resting.
- I tried to jump start the van with some jumper cables and a mate's car.
- I measured the battery again afterwards and it read 13.2 v.
- I had a look at the fuses and they seemed fine.
- I removed the flasher unit from the central console and it makes no difference. You turn the ignition key and absolutely nothing happens.
I'll go to the car again today to check the fuses and relays and try to get a video of the whole problem if it helps.
Any help would be greatly appreciated guys, because at the moment I am stranded in a small town 400 km from home, and even worse, in about a month I need the car to be reliable for a long journey.
Cheers,
Nick
Cheers,
Nick
