Technical  Ugly bug dead
Mikes multipla
South africa
Hello everyone my bug is still a no go bought a new map sensor and turbo solenoid valve cleaned the map sensor but still no go egr blanked off will start the car will idle and rev up quit fine for like 10 seconds then won't rev up after that can put my foot flat on the accelerater but nothing just smoke
It's a light colour it's more like a grayish colour it's not blue and it's not black when I start the car it will rev up for like ten seconds in that time the rod on the actuator will move all the way like 2-3 cm after that I can put my foot flat and nothing will happen
If you put a fold in the little pipe to the turbo actuator (double it back on itself, then use a clothes peg or bulldog clip on the hose to keep it that way) does it have any effect on things?
That smoke - is that when you start the engine from cold?
The smoke starts after ten seconds of idling If I pull the red pipe off to the actuator or any other Black vacuum pipe off it cums right then I can drive the car but I can feel the car lacks power the turbo doesn't work like it should it seems to be a constant vacuum
Have you checked out the accelerator cave also check the two hoses at the front right bottom of your engine as mine had no power and one of theses hoses went connected.
Vicar
