i messed around with this a while ago ^ does work, rear wipers are naff anyway
just wondered if your bottom radiator hose is a bit close to your inter cooler`s pipe at the bottom? dont know if thats the inlet or outlet from the IC?
played with TB's to. i fitted a smaller one to see if it helped the cars rough idle (it never and i fixed it with loads of messing with maps)
what i did find is boost took longer to raise this could be seen in the datalogs but the main effect was off boost where the car was noticeably less responsive.
checked that... looked like is was at first (been removed as some point and had hit but i bent in where there was a shiny bit (first lobe on the first pot) and no effectcould be 2 things....
check the **** plate in the cam cover aint hitting the cam (i had this happen on my enigne before)
or if it does it when acelerating or decelerating its deffently knock, mine done it got worse and worse till it blew up
nope... its tight but thats how they all seem to be.just wondered if your bottom radiator hose is a bit close to your inter cooler`s pipe at the bottom? dont know if thats the inlet or outlet from the IC?
I dont plan to drive thru any brooks soo should be fine1st the filter in that position is too low in is at risk of sucking in water
2nd that is where your oil cooler should be
Have you retarded the ignition to see if you still have the noise if it goes awayi t could be knock but at the CR you are at i doubt it will be unless you have totally screwed up the fuelling, also for a petrol engine you are looking to hear knock at ~7KHz wich is why quite often it is refered to as pinking or ping
but the golden rule with any FI engine if you have any doubt wind back the the boost
That is close but that is how things are on VAD setups, it is the only way to fit 3 ratiatiors in the front of a cinq and supply them with cold air
i could have gone from a 2mm tb to a meter wide tb... wont do anything at idle. the engine has done it since i fitted it (and could of before for all i know)would you say the boost was more controlable with ths smaller T/B?
when did you start getting the knocking/ping and with which throttle body?
cos if you mapped it with a smaller T/B and fitted a larger one without re doing the load maps im not totally sure but that could play a part IF the engine is pinking?, more air passing at a given mapped load site with the larger T/B
What timing you running at idle? Is it verified with a strobe, timing marks, and checked by piston height with a dial gauge?
The filter that low is a killer, i ran a feed that lo, and nearly killed my engine when it rained heavy once.
Is it def from the eninge? or could it be the input shaft to the box?
Kristian
