theoneandonly
Prominent member
Have you got a screenshot of the freeze frame data?Well, changed the MAP sensor and the boost solenoid, but still the same issue - po236. Runs fine until I get about 2 miles up the road and start accelerating out of town. Attached a graph of desired vs actual boost, if this can help? You can see where the engine light comes on and the turbo gets shut down.
Any csv files?
Have you checked the turbo actuTor?
For canbus errors need to check ecu connectors, clean connections
