I think if someone wanted £900 for the job, I would belt them never mind the car. Workshops have set times for belt replacement. Bits of string not needed
Thanks. A grown up replay and without any talk of stringShop 4 Parts have the SKF timing belt kit for under £60 https://www.shop4parts.co.uk/?name=store&op=Product&ProdID=26667
Shop 4 Parts cam belt cover (often broken) https://www.shop4parts.co.uk/?name=...Panda_II_(04_to_09)_1.4_16v_Timing_Belt_Cover
You will also need the correct engine locking tools. The cam lock tool has a spring loaded pin. You screw it into the side of the cam cover with the flats vertical and turn the engine until the pin drops into place. You then fit the crank locking tool. Cam belt is fitted and tensioned with the cam wheel loosened. You will need a pulley holding tool to prevent overloading the cam and/or the cam belt as you torque it up.
This looks to have all you will need https://www.ebay.co.uk/itm/393679745850?hash=item5ba924333a:g:6wQAAOSwoABhEkMn
3 hours with aircon not including water pump or serviceI think if someone wanted £900 for the job, I would belt them never mind the car. Workshops have set times for belt replacement. Bits of string not needed
nopeIs there a big difference between the 1.4 100hp and the normal 1.2 engines? I've done several 1.2 timing belts and the last one I did under 90 minutes on the street. the biggest challenge i got was that I could not find my special tensioner tool so I needed to use a set of needle nose pliers...
the engine looks the same according to this thread https://www.fiatforum.com/threads/100hp-cambelt-changed-do-i-need-to-do-a-phonic-relearn.452300/
That must be the best price I've heard for a main dealer normally closer to £300 and doesn't usually include the pump at that price£240 including vat and water pump with a warranty sounds good to me
