The rear axle adds the complexity of brake pipes and bleeding marks everything afterwards, the front is mainly just bolts so it would be logical to suggest the rear would cost a little more, but that said who knows
I'm still hoping that once my hip is replaced I'll be up to doing this myself. I'd like to do it myself. Just have to wait and see how it all goes. Becky's MOT is due March next year and I'm hoping the op can be scheduled for September/October. They say the recovery from a hip op is much quicker than knees and I recovered from them quite quickly, So maybe?The rear axle adds the complexity of brake pipes and bleeding marks everything afterwards, the front is mainly just bolts so it would be logical to suggest the rear would cost a little more, but that said who knows
You'll be up and about the same day. Knees are much more painful and take a lot more physio to get the range of movement back, hips not so much you have the range of movement and less pain so much easier to get going and get back to normal.They say the recovery from a hip op is much quicker than knees and I recovered from them quite quickly, So maybe?
Well done!
A man after my own heart!
Don't know but Kenny's wee FIAT specialist garage - where I go for my MOTs and all general knowledge - has quoted me "in the £600 region" to put a new rear axle in Becky, as long as nothing goes "dramatically" wrong.
I am going to tackle the rear subframe on the punto soon, not looking forward to it. It is a whole subframe assembly with shocks, springs and brakes and brake balancer all attached so all comes off in one piece but being at the back of the car the bolts and screws are subject to much more salt and water from both the front and rear wheels kicking stuff up from the road
Still for 25 years old the subframe is solid Fiat really dropped the ball on these newer 500s and Pandas, you'll definitely see a lot of much newer fiats in scrap yards thanks to rust issues.
I like using my air gun on stuff like this and letting it rattle them gently between "tighten" and "loosen" a few times before really trying to undo them.I was lucky that the front subframe bolts came off easily, the car has had new control arms and the subframe had been dropped to get them on, so the bolts had been unbunged in the not too distant past.
I presume this works in reverse, i haven't given the subframe bolts a final tighten yet becaue i may have to lower it a little to get the arms back on. So i'll bear this in mind.I like using my air gun on stuff like this and letting it rattle them gently between "tighten" and "loosen" a few times before really trying to undo them.
I'm talking about bolts (and nuts) which I suspect may be either very tight or corroded in place. Applying some shocking forces with the impact wrench by trying to tighten, loosen, tighten, loosen a number of times, ie. "shocking" the fixing, before trying to actually undo them often sometimes the corrosion - a good spray of Plus Gas is also recommended. It's no mistake that I've put "tighten" first as this action alone sometimes breaks a seized bolt free.I presume this works in reverse, i haven't given the subframe bolts a final tighten yet becaue i may have to lower it a little to get the arms back on. So i'll bear this in mind.
Ive put a video up of it not best work. But the wrench is great qualityI would at that price if its an adjustable one. Worth a gamble. I have not yet bought anything that I felt was rubbish.
I took the pinch bolt out of my Panda, it was a pain to get it back in! In the end I had nearly given up and it fell back on as easy as you like. It may only go back in one position. Don't force anything just gently persist and it will go back. Move the steering wheel slightly side to side a few degrees to realign the splines, but again dont overdo it. I now make certain the wheels are straight before starting then when you put the steering wheel straight you know its on right. Check where the wheels are pointing and adjust steeering wheel to match. You may need to move the joint up the column to align the bolt ithe the slot in the column. Try a small screww driver in teh hole to help align things.I got one of the control arms on tonight - with a struggle. But the other one just wouldn't go in at all. There's some knack to it that I don't know?
I also tried to reconnect the steering column pinch bolt in the cabin, but it didn't want to go in easily and I was a bit too worried to try and force it. There is a spline or flat bit on the column but as i haven't moved the steering it should have just slide back on? Or is there something i'm missing?
I will give that a try. Appears it wants an exact angle.I took the pinch bolt out of my Panda, it was a pain to get it back in! In the end I had nearly given up and it fell back on as easy as you like. It may only go back in one position. Don't force anything just gently persist and it will go back. Move the steering wheel slightly side to side a few degrees to realign the splines, but again dont overdo it. I now make certain the wheels are straight before starting then when you put the steering wheel straight you know its on right. Check where the wheels are pointing and adjust steeering wheel to match. You may need to move the joint up the column to align the bolt ithe the slot in the column. Try a small screww driver in teh hole to help align things.
You can end up with the steering wheel misaligned apart from looking bad self cancelling indicators are mucked up and you cant see the dials when going along.. If this happens you have to get the wheels straight and then remove and refit the wheel in the straight ahead position, so worth checking it is straight before final tightening. The Panda book says replace the pinch bolt every time its removed. I havn't done this, but its important not to overtighten it. I use a small amount of low adhesion nut locker and torque it as specified. I shall get a few bolts in stock when next at our local bolt and fixing stockist.I will give that a try. Appears it wants an exact angle.
What's so bad about turning the steering wheel? I haven't because I've read it's bad, but would like to know.
The steering column and steering rack splines must line up exactly, so if not sure put a little tippex mark where the flat or blank is on the spline and check the column shaft matches exactly, as @The Panda Nut says do not force it , once in correct position it should slide onto splines easily.I will give that a try. Appears it wants an exact angle.
They are grade 10.9, not the usual 8.8.I shall get a few bolts in stock when next at our local bolt and fixing stockist.
Dont tighten bolts up with an impact gun, there's a good chance of shearing or stripping themI presume this works in reverse, i haven't given the subframe bolts a final tighten yet becaue i may have to lower it a little to get the arms back on. So i'll bear this in mind.
Absolutely. I have two air impact guns, one is a cheapie Machine mart jobbie which would be hard pushed to skin a rice pudding the other is a Chicago Pneumatic which I bought to tackle stuff like the notoriously tight crankshaft front pulley bolt on my daughter in law's Jazz. It's an absolute animal! It actually has 3 presets which limit torque but I wouldn't trust it. Absolute magic at undoing tight stuff though!Dont tighten bolts up with an impact gun, there's a good chance of shearing or stripping them
Given that their only real purpose, what have you been doing with it???I have an impact gun but hadn't thought to use it to loosen nuts and bolts with a juddering action,
