General  NoFPS
General  NoFPS
JackPitt99
Tywyn
I’ve recently started getting NoFps on the dash, the car is working absolutely fine but it’s a bit of an annoyance, how do I go about sorting the issue? I’ve tried the indicator reset and can’t seem to do it, unless I’m doing it wrong!
Model
Fiat Grande punto Sound
2011
Mileage
80080
If you pull the fuel pump relay, same message pops out.
Try this direction. Connections in the main fuse/relay box. Cleaning.
Fault code is about information flow in the CAN lines. Power quality is the first thing to check. Including main ground/earth.
Maybe alternator is failing slowly (for example charging 14,0 or lower). Charge the battery anyways.
Fuel cut-off is triggered by AirBag module, then Body Computer manages it (to cut or not to cut it out).
Reset is a software option in FES/MES. And CAN lines to be checked with oscilloscope (if the signals are clean, proper levels).
Despite name of the function, there is no "inertia switch" anymore from 2009 or so (it's a software thing: AirBag + BodyComputer talking via CAN).
And you have "2011", so EVO (not Grande, wrong forum section).
I mean it’s definitely a grande punto and it’s an 11 plate. It’s a frustrating issue to have, but doesn’t affect the car at all.
