A lot is being said about fast charging in just a few hours but I'm wondering, with most batteries, if you push high rates of charge into them they degrade much more quickly than if you "trickle charge" them. Does the same rational apply to these EV car batteries or are they completely different "animals" altogether?
Won’t cause an issue. At the end of the day a fast charger is 7kw.
The battery will have significantly higher draws in and out when driven under full acceleration or regenerative braking.
What does cause issues is high temperatures (not an issue on modern EVs as most now have active thermal battery management, but an issue with the Nissan Leaf which still doesn’t) and leaving the battery at very high or low states of charge for extended periods of time when not needed.
