I doubt anything at the moment is wrong with the gearbox. Just the selector
I wouldn’t start the engine until we are sure what’s going on
I wouldn’t start the car with the selector off
It’s possible to accidentally select two gears at the same time and cause a lot of damage.
I be tempted to drop the car onto its wheels and gently try pushing it in neutral
I'll second that.
Never start an engine if you suspect any part of the transmission is not free to move as intended.
Move the parts by hand, using as little force as possible, until you discover what exactly has locked up.
Not sure where to go with thisThe car isn't pushing *fine*, I can feel the engine compression as I'm pushing it (feels like pushing over a speed bump).
I thought we were just dropping the car and rolling it to see if it’s the angle of the driveshafts in the differential causing a problem
Not shoving so hard it turns the engine over
I feel what stared as a simple problem is going to end in tears
