I posted here a few weeks back about my Punto having a couple of problems. The first was a starting problem with the imoboliser not always switching off. Weirdly, after a couple of days it stopped happening. The second was a rattling which I thought was the alternator belt. It was, as it started squeaking when first switched on in the morning. The garage I took it to found the problem was the oil pressure switch leaking oil onto the alternator belt, so replaced the oil pressure switch and the alternator belt. They also confirmed the oil level was still between the min and max marks so it hasn't lost too much oil.
However I still have the rattling sound, although the squealing has stopped and it seems to be getting louder. It is worst in 3rd gear but I don't think it's coming from the engine, as if you drop the clutch and rev the engine it sounds fine and there is no rattling. However when the clutch is engaged, the rattling sound is there and as the engine speeds up so does the rattling, and vice-versa. I don't seem to have any issues changing gear, but am worried it might be the gearbox. The car has done just over 89,000 miles. I hear mention on here from time to time of the gearbox oil. I'm not sure how to check the gearbox oil level however - can anyone advise? It's a mk2, 2001(Y), 8v petrol.
