Re: were everythingis on a 1.2fire engine 2000 onwards
Wonderful pictures - I wish the real thing had chrome-plated bolts and perfectly-clean (or silver-painted) aluminium!
I believe that the plastic sensor plug visible to the right of the phonic wheel (in the third pic) is the oil pressure warning light switch (EDIT: D'uh, I see you already captioned that in the first pic ).
This engine is similar to the Uno 999cc and 1108cc engines back as far as 1986, except for the fitting of more modern components like the close-coupled catalytic converter, plastic intake manifold, fuel injectors, and that strangely-tiny ECU.
hi can you tell me how much weights the FIAT PUNTO 1.1, 55HP, 1995 production year only engine with other parts thet nedded to be in run. beacse i like to use this engine for glider trike but i cant find the weight which is important to me thnx.
